Filter for TCP/UDP
coolhaus
Filter for TCP/UDP
Post by coolhaus » 17 Aug 2023, 13:33
Hello, please advise. I have 2x10gbps connectivity and I want to solve the dofilter through attacks in dynfi.
TCP/UDP protocol, where you can set the blocking of specific numbers of packets in the firewall? Thank you :roll:
Re: Filter for TCP/UDP
Post by gregober » 17 Aug 2023, 23:47
You should be able to do that in the advanced pannel of firewall rules.
This shall allow you to speify parameters such as:
  • Max states
  • Max source nodes
  • Max established
  • Max source states
  • Max new connection
