Driver RealTek
nonobis
Driver RealTek
Post by nonobis » 08 Feb 2026, 18:22
Comment installer le package os-realtek-re.pkg sur dynfi ? de la meme maniere que opnsense ?
Désolé question idiote en premier poste mais je ne veut pas pourrir pmon install toute neuve avant de tester :)
Merci :)
Re: Driver RealTek
Post by gregober » 09 Feb 2026, 10:53
DynFi firewall ne fonctionne pas avec le principe des packages.
L'ensemble des packages sont "pré-installés".
Donc si ce package ne figure pas dans les packages pré-installés, vous allez avoir du mal à l'installer.
Étant donné que nous utilisons l'installation par défaut de FreeBSD, il doit être possible de l'installer directement depuis FreeBSD.
Je vais demander à l'équipe de dev de vous répondre…
oshogbo
Re: Driver RealTek
Post by oshogbo » 09 Feb 2026, 14:24
Unfortunately, since this is a kernel module and we provide a custom kernel, it is not possible to download a kernel module that is not built specifically for a given release. You can build the module yourself, but it can be a bit of a hassle. Would you like help with this?
I would also like to add that we are very interested in your opinion. This package seems very interesting, and we are considering adding it to our release. Thank you for your feedback.
nonobis
Re: Driver RealTek
Post by nonobis » 09 Feb 2026, 16:33
Hello @oshogbo,
I’d like to test DynFi with my Realtek dual-port 2.5GbE NICs. If you’re willing to help guide me, I can try building it on my own hardware.
I found the package here, but not the full source repository:
https://pkg.opnsense.org/FreeBSD:13:amd ... st/Latest/
This package works on OPNsense without any issues, for your information.
I’m a senior .NET developer and fairly comfortable with development in general, though I’m not an expert in Linux/BSD. If I can help with testing or building, I’d be happy to contribute.
oshogbo
Re: Driver RealTek
Post by oshogbo » 13 Feb 2026, 21:16
Sorry for late response.
Which version of device os are you using?
I might prep a package for you.
