26.1.0 released on 10/6/2026
Post by gregober » 08 Jul 2026, 20:26
  • Added "Add new rule” option - from now on DynFi Manager allows adding new rules on a device. When adding a rule DFM provides a sane default values.
  • Rules are added at the end of the list.
  • Added “Clone rule” option.
  • Handled multi-value source/dest fields introduced by OPNsense 25.1. Now it's possible to choose several aliases and/or defined networks.
  • Handled multi-value icmptype rule field. Introduced for IPv4 by OPNsense 25.1.6, IPv6 by OPNsense 25.7.11.
  • Config details search improvements.
    - Search runs when typing and on enter, it’s case insensitive.
    - Added search forward/backward with buttons and enter/enter+shift shortcuts.
    - Fixed highlighting of found phrases, additional visual improvements.
    - Improved search accuracy.
  • Fixed FQDN search on config list.
  • Fixed rule restrictions mechanism on OPNsense. DFM doesn’t use labels to identify automatically generated rules. As long as a rule has uuid, it can be restricted.
  • All other rules (mostly automatically generated and non-migrated legacy rules) are restricted by default (and can’t be unrestricted), as they don’t have any immutable id.
    Doesn’t affect pfSense.
  • Handle edge cases of rule’s direction field, so that DFM behaves and displays direction in a similar way as OPNsense / pfSense admin panel.
  • Fixed editing floating rules - in some cases it wasn’t possible to edit a floating rule while it should be.
