GUI SSL Cert
michael
GUI SSL Cert
Post by michael » 04 Nov 2022, 08:33
Hi,
I have got dynfi firewall manager install and my first firewall added using the connection string. Other than a few issues installing mongod it's all been a simple process.
I would like to add a lets encrypt certificate for the webgui, I can't see a way to do this. So I was going to generate my own certificate and symlink it to the dynfi one. Could you tell me the path for the current self signed certificate? Or should I create my own java keystore and then point the config to that?
Thanks
Michael
michael
Re: GUI SSL Cert
Post by michael » 04 Nov 2022, 09:17
To those of you who want to do this, I followed this article and my dynfi instance is now secured with let's encrypt!
https://ordina-jworks.github.io/securit ... -Java.html
Re: GUI SSL Cert
Post by gregober » 04 Nov 2022, 10:11
Thanks a lot for your feedback and pointer ;-)
