Utilise DynFI Syslogs to push server logs to same place?
You would like to see new features embedded in DynFi Manager, you can make proposals or discuss that in this forum.
Re: Utilise DynFI Syslogs to push server logs to same place?
Post by gregober » 16 Sep 2019, 10:20
If you mean:
hilla_kh wrote: ↑30 Aug 2019, 13:46 Is it possible to utilise DynFi Syslogs to push (firewall) logs to same place? :idea:
Yes: It is possible to log your firewall's log on the same device as DynFi.
Just make sure you have setup your DynFi syslogd correctly to allow FW logs to be collected and stored properly on your DynFi Server.
Since firewall log can get quite big, I would also suggest that you setup a policy using logrotate in order to limit size taken by olderl logs on disk.
hboxhorn
Post by hboxhorn » 20 Sep 2019, 22:09
Could you provide us with a example install of this ?
