Config import from Opnsense ?
frescom06
Post by frescom06 » 03 Nov 2022, 13:38
Hello all,
I currently testing DynFi, and have been using Pfsense and after OpnSense from years.
Since Dynfi is a fork from OpnSense, does it means I could use an OpnSense backup to import the configuration I want into Dynfi ?
Is this possible or not ?
BR,
Re: Config import from Opnsense ?
Post by gregober » 03 Nov 2022, 15:06
Hello frescom06,
frescom06 wrote: ↑03 Nov 2022, 13:38 Hello all,
Short answer: you should be able to import your config from OPNsense into DynFi Firewall.
Longer answer: depending on the version of OPNsense you are using and the "plugin" you have enabled on It, some part of the config might be missing / obfuscated. Normally this shouldn't cause major problem…
We will upgrade to a newer version of OPNsense in the coming months so you should be able to have a larger support from most recent functions (new alias types, and misc other functions).
frescom06
Post by frescom06 » 03 Nov 2022, 15:24
Tested from Opnsense 22.7.6 to last Dynfi Version : works like a charm ;)
Merci :)
Post by gregober » 03 Nov 2022, 23:41
frescom06 wrote: ↑03 Nov 2022, 15:24 Tested from Opnsense 22.7.6 to last Dynfi Version : works like a charm ;)
Merci :)
Good to know!
Thanks for the feedback. :D
