Virtualizing DynFi on ESXi v8
fatek
Post by fatek » 10 Jul 2023, 10:28
Since DynFi can be run as a vm in ESXi according to this:https://dynfi.com/documentations/dynfi- ... _ESXi.html
How do you install VMware tools in the vm?
VMware tools is necessary for smooth operation of the vm.
Rom1
Re: Virtualizing DynFi on ESXi v8
Post by Rom1 » 16 Dec 2024, 16:37
Hi,
You have package in System > Firmware > Packages : open-vm-tools-nox11
I also need to add
vmware_guestd_enable="YES"
in /etc/rc.conf if vmware don't see the VM tools after reboot.
Best
Post by gregober » 16 Dec 2024, 23:12
Yes, thanks @Rom1 for the reply.
We still need to work on adding a GUI to enable / disable the VMware tools directly.
Not a big effort, but we still have to do it…
