problems to access internet thru DynFi
omppa
Post by omppa » 14 Jan 2025, 14:39
Hi,
I just got DynFi installed and after that i run setup wizard. Could somebody kindly tell that what more i shoud do that i manage to get internet Accsess? :)
-omppa
Re: problems to access internet thru DynFi
Post by gregober » 14 Feb 2025, 11:09
You should have one cable plugged on the Internet (to your service provider) and another one on your LAN (generally on your switch).
After that you need ton configure the interfaces following your internal requirements.
