26.0.0 released on 12/03/2026
Post by gregober » 12 Mar 2026, 12:47
  • Added firewall rule editing directly from DynFi Manager
    - Rules can now be modified, disabled, deleted, and reordered without
    accessing the firewall's own administration panel.
    - Enter Edit rules mode from the Rules list page; the page header turns
    red to indicate an active editing session.
    - The edit button opens a Modify rule modal allowing changes to action,
    interface, protocol, source, destination, TCP/IP version, and more.
    - The disable/delete buttons are available directly on the Rules list.
    - Select one or more rules and use the arrow buttons to reorder them
    above or below any other rule in the list.
    - All changes are accumulated locally and only applied to the firewall
    upon clicking Apply changes. Clicking Cancel discards all pending changes.
    - Requires the "Create rules" permission.
  • Added ability to disable email notifications per device
    - Email notifications can be toggled globally in System settings, but
    it is now also possible to disable them for a specific device. This is
    useful for devices that drop connection frequently and would otherwise
    generate excessive notification spam.
  • Added scheduled device reboots
    - A scheduler has been added on the device details page and device list.
    It is now possible to choose between rebooting a device(s) immediately or
    scheduling the reboot for a later time.
