27.0.0 released on 16/11/2026
Post by gregober » 16 Nov 2026, 10:22
  • Added Rule collections. A set of firewall rules can now be defined once in DynFi Manager and pushed to many firewalls, the same way Alias collections work.
  • Collections are managed under the new Rules > Collections menu. They can be created, edited, cloned and deleted. Their rules are edited the same way as device rules (add, clone, modify, disable, delete, reorder).
  • Each collection is made for either OPNsense or pfSense. Its rules don't depend on any one device: the interface is chosen per firewall during synchronization, and the Schedule, Gateway and alias fields aren't available.
  • A cloned collection can have a different target distro, which makes it easy to build a pfSense version of an OPNsense collection.
  • A synchronization wizard handles device selection and the interface choice on each device. New rules can be placed at the bottom, at the top, or after a specific rule chosen per firewall. Rules pushed by an earlier synchronization are updated in place.
  • Expert mode controls what happens to rules found only in the collection, only on the device, or in both: create, replace, skip, delete, or report an error.
  • Each device's update is all or nothing: either every change is applied or the device's rules are left untouched.
  • Collections have their own permissions (Read, Create, Write, Delete, Synchronize).
  • Added Rules updates. Every change DFM makes to a firewall's rules, whether from Edit rules mode or from a collection sync, is now recorded and listed under Rules > Updates. Each update shows its status and exactly which changes were made, and failed changes are highlighted.
  • Added rule validation. Before a rule is saved and before changes are sent to a firewall, DFM checks that the rule's fields are consistent with each other (protocol vs. port, ICMP type, gateway vs. IP version, and so on). It also checks that the aliases, interfaces, gateways, schedules and categories the rule refers to exist on the firewall. Invalid rules are listed and nothing is sent until they're fixed. When an existing rule is edited, only the changed fields are checked.
  • Rules list improvements:
  • Interfaces disabled on the firewall are now marked "(disabled)".
  • The Operations column is shown only in Edit rules mode.
  • "Apply changes" stays disabled until something has actually changed.
  • Updated rule permissions. Edit rules mode is no longer limited to full-access administrators. Adding a rule now needs the same permissions as the rest of Edit rules mode. The Rules menu is shown only to users in a device group, the same as Aliases.
  • Fixed several issues when editing rules:
  • The floating flag was lost when editing OPNsense floating rules.
  • New OPNsense rules could be saved at the wrong position.
  • Unchecking "Quick" was not saved correctly on OPNsense, and the quick/last-match icon on the Rules list was wrong.
  • Port fields could reset while typing or revert to "any".
  • ICMP type and port weren't cleared when the protocol changed.
  • Multi-value source/destination and ICMP type fields fell back to single values on newer OPNsense versions.
  • The gateway selector showed the wrong default.
  • Loopback is no longer offered as an interface on OPNsense 25.1+.
  • New pfSense rules now get unique IDs (trackers) generated the same way pfSense does it.
  • Improved reliability of rules and alias updates when several devices are updated at the same time.
