20.2.0 released on 2020-02-28
Post by gregober » 04 Mar 2020, 10:21
* Fixed missing hostname in widget headers
* Updated translations
* A tag can be deleted from all devices with single click
* Added new tags widget also to device creation form
* Added French translations
* Tags sidebar: added "devices selection dialog" for mass tagging
* Using single endpoints for mass tagging
* Tags sidebar: replaced icons with dropdown menus
* Added mass-operations for tags: add to selected, remove from selected, remove from all (accessible).
* Tags sidebar: added confirmation dialog to mass tag operations
* Tags sidebar: mass tags updating on selected devices (when viewing a devices list)
* Tags sidebar: adding/removing tags to currently viewed device
* Added tags list to sidebar
* Added tags to marker boxes on devices map
* Layout fix for inline tags editor in devices list
* Inline tags editing in devices list
* Added inline editor for device tags
* Handling more than one tag in search field
* Editing tags of single device directly from devices list
* Editing device tags directly from header info
* Added info header with tags to all device-related pages
* Devices status page: added info header with tags
* Tag list is no longer added to alias updates
* Some UI improvements for device tags
* Added tags-autocomplete to search field (enabled by starting search with "#")
* Added devices sidebar filtering by tag
* Devices list: bulk tagging tool supports tag removing
* Devices list: added bulk tagging tool
* Fixed tags handling in bulk alias update form
* Added quick change to enable tag filtering in flatDevices as well.
* Made DeviceTag names returned using the order of occurrences.
* Device tags support in aliases synchronization form
* Device tags UI: Handling case-insensitiveness
* Updated tags editing and searching
* Aliases: Added device tags columns to device selection modals
* Displaying tags in devices list
* Added form for editing device tags
* Added possibility to store device tags in BulkAliasUpdate.
* Added basic endpoints to allow changing devices' tags.
* Added basic endpoints to read tags.
* Introduced tags in Device.
