No redirection after setup wizard
dagonix
Post by dagonix » 16 Nov 2021, 15:15
When you run the wizard after install and if you change the LAN IP address, the redirection will fail because you'll be redirected to the former LAN IP address.
Re: No redirection after setup wizard
Post by gregober » 16 Nov 2021, 15:42
Thank you for reporting this problem. We will try to fix it.
[b]Please try to post in the DynFi Firewall section if questions are related to DynFi Firewall. [/b]
dagonix
Post by dagonix » 16 Nov 2021, 18:09
Sorry, I posted to → Using DynFi Firewalls / General questions. I don't see a section called DynFi Firewall :)
And by the way, the no redirection problem is not only "Wizard related". Even after the setup, if you change the LAN address IP, the redirection does not occur. The same goes if you change the TCP port.
Thank you.
