23.2.0 released on 2023-09-13
Post by gregober » 05 Oct 2023, 14:51
* Prepared traslations for milestone 23.2
* Fixed address for devices using Connection Agent
* Added a warning before config restore
* Fixed setting os version of initial config
* Fixed getting OS version for config
* Fixed getting the date of the oldest config to keep for device
* Fix config restore refactoring issue
* Added restoring firewall config from DFM to selected device
* Extracted ConfigComparator to a widget
* Removed trailing spaces
* Added link from gateway widget to performance board
* Fix keeping at least one config when deleting the old ones
* Fix missing header icons after page reload
* Fix formatting
* Added links to documentation in various places
* Add setting for deleting old device configs
* Fixed default column visibility for performance statistics table
* Added global setting for session timeout
* Renamed user property "token duration" to "session timeout"
* Fixed getting device address for scheduled action
* Changed presentation of performance statistics
* Changed default column visibility for performance statistics table
* Removed default avatar on top left of the sidebar
* Changed default column visibility for device related tables
