Docker Install
SMiTTY4x4
Docker Install
Post by SMiTTY4x4 » 05 Dec 2023, 19:41
I found that the links to docker were very old, and really didn't work well. I prefer Ubuntu, so feel free to modify to you hearts content :)
1. Download https://dynfi.com/files/dynfi/dynfi-23.2.2-all.jar
2. Place all of these in a single directory and run docker compoes up -d or docker-compose up -d
3. Adjust the location of your dynfi.conf and make any changes you see fit. I have Agent Connection enabled in mine
4. Access your Dynfi Manager on http://localhost:9090
This was an attempt to fix old documentation. Maybe I'll create docker images and do away with the Dockerfiles. It could be so much more robust :)
Dockerfile_Java
FROM ubuntu:22.04
ENV DEBIAN_FRONTEND=noninteractive
RUN \
  apt update && apt -y install gnupg wget openjdk-11-jre-headless apt-utils && \
  apt-get clean && rm -rf /var/lib/apt/lists/*
# install Mongo Shell
RUN \
  wget -qO - "https://pgp.mongodb.com/server-6.0.asc" | gpg -o /usr/share/keyrings/mongodb-server-6.0.gpg --dearmor && \
  echo "deb [ arch=amd64,arm64 signed-by=/usr/share/keyrings/mongodb-server-6.0.gpg ] https://repo.mongodb.org/apt/ubuntu jammy/mongodb-org/6.0 multiverse" | tee "/etc/apt/sources.list.d/mongodb-org-6.0.list" && \
  apt update && apt -y install mongodb-org
# Create DIR config
RUN mkdir -p /data/conf
WORKDIR /data/app
COPY dynfi-23.2.2-all.jar .
# Define mountable directories.
VOLUME ["/data/conf"]
Dockerfile_mongo
FROM ubuntu:22.04
RUN \
  apt update && apt -y install gnupg wget && \
# install Mongo
RUN \
# Create dir Mongo
RUN mkdir -p /data/db
RUN chown mongodb:mongodb /data/db
VOLUME ["/data/db"]
#CMD [ "mongod" ]
docker-compose.yml
version: '3'
services:
  dynfiapp:
    container_name: dynfiapp
    hostname: dynfiapp
    build:
      context: ./
      dockerfile: Dockerfile_Java
    volumes:
      - ./dynfi/conf/dynfi.conf:/etc/dynfi.conf
      - ./dynfi/mongo-db:/data/db
    ports:
      - '9090:9090'
    command:
        java -jar /data/app/dynfi-23.2.2-all.jar --config /etc/dynfi.conf
  dynfidb:
    container_name: dynfidb
    hostname: dynfidb
    build:
      context: ./
      dockerfile: Dockerfile_mongo
    volumes:
      - mongo-db:/data/db
    ports:
      - '27017:27017'
    command: mongod --bind_ip 0.0.0.0
volumes:
  mongo-db:
    driver: local
dynfi.conf
# This is DynFi? Manager configuration file.
# This file must follow properties format: https://en.wikipedia.org/wiki/.properties.
# Run `dynfi help` or visit http://dynfi.com for more help.
connectionAgentPort=2222
ipAndPort=0.0.0.0:9090
useHttps=false
mongoClientUri=mongodb://dynfidb
mongoDatabase=dynfitest
Re: Docker Install
Post by gregober » 05 Dec 2023, 20:11
Thanks a lot !!
This is really cool :D
I will make sure that we re-transcript this post in order to make it available and that you'll get the credits for it !
So nice !
