24.1.0 released on 2024-10-14
Post by gregober » 14 Oct 2024, 12:12
Added widgets related to high availability & clustered firewalls
  • Virtual IPs widget, displays all virtual ips for given machine
  • CARP status widget, displays CARP interfaces and their status (MASTER/BACKUP)
  • High Availability widget
    - basic HA config
    - synchronized services
    - status of services running on BACKUP firewall
    - button to force config sync on DynFiFirewall & OPNsense
  • Fixed various bugs related to Network & VPN section
  • Fixed getting version of DynFiManager 4.x
  • Allowed swapping backup connections with primary connection
    - Any of backup addresses can be promoted to be the primary one
    - Addresses can be reordered
    - Previous primary connection can be deleted (but current one can't)
  • Added "States details" tooltip on rules list
    - This tooltip displays traffic data related to given rule
  • Hid incomplete rules until they're fully fetched from firewall
  • Improved info about rules
  • Fixed OPNsense & DynFiFirewall rule ids
    - Rule ids in DynFiManager now correspond with 'label' param on Firewalls
    - Existing rule restrictions are adjusted to new ids
    - Fixed pfSense rule ids' inconsistencies
  • Made SMTP user & password optional in e-mail notification settings, to support servers which don't need credentials
  • Cleaned config history on settings change
    - From now on, each save of config history settings (global or device-specific) will result in performing the check and removal of config meeting chosen criteria.
  • Fixed various bugs related to adding/editing/validating aliases
    - Network Group alias validation on edit
    - Serialization of URL (IPs) alias when there's more than one url
    - Fields disappearing on validation in add/edit alias form
    - Various validation issues
  • Refactored rules, aliases, network & vpn; added automated tests
  • Upgraded Backend & Frontend dependencies
    - To avoid using outdated dependencies with possible vulnerabilities, DynFi Manager is regularly scanned with OWASP dependency-check tool.
  • Remove unused Frontend dependencies
