DynFi Manager: Ability to change primary connection/IP/DNS of device
You would like to see new features embedded in DynFi Manager, you can make proposals or discuss that in this forum.
ltcadmin
Post by ltcadmin » 23 Jul 2023, 18:51
Currently I am unable to find a way to change the primary connection method of a added device. While one can add a secondary ("Edit backup connection addresses") method, the primary is hard set.
If a connection must be edited for IP/DNS change, the device must be deleted & re-created, purging configuration history.
Re: DynFi Manager: Ability to change primary connection/IP/DNS of device
Post by gregober » 24 Jul 2023, 16:59
This is correct.
In order to avoid all sorts of problems tied with device creation, we thought that It would be better NOT to allow editing a device after it has been setup.
ltcadmin
Post by ltcadmin » 31 Jul 2023, 04:43
Just wondering, is this something that can be re-thought? It would be great to be able to change the primary connection string without loosing the device history/configs etc.
Post by gregober » 31 Jul 2023, 10:28
Yes, this is something that can be rethought.
Today you should be able to use the secondary IP address and it shall be able to switch.
astojanowski
Post by astojanowski » 06 Jun 2025, 14:03
Hello,
This feature has been implemented in DynFi Manager 24.1, see https://dynfi.com/documentation/backup- ... s.html#id2.
